Bleeding, slow and not very natural
Michael Earley
As you can see, I have a bad bleed of the yellow line in this image. Also it looks very cartoony
I have attached a link to my settings, I have used a combination of many of the threads I have found here, mostly natty and I think it is like putting a bunch of colors into a bucket.. they all look good on their own.. but together.. any ideas as what I should do or change?
This is an animation and the images are already in the 25 min plus category and I have a few thousand to do. I am now trying to change to med animation and see if that helps, it is a big model and I have already cut out all I can .
thanks
Michael
Hi,
lower the first diffuse bounce and the second one to to 1 and .5 respectively. I found they cause things to be overillumonated and less contrast... Medium worked fine on a few animations I did so don't worry use medium.
instead of using high multipliers for the first and second bounces use mor elights or better positioned lights.
thansk,
Ihab
Thanks guys, ihabkal I did not notice that the shadows had gotten turned off, that would explain the cartoony look. I have made the changes and I am rendeing now, but with the shadows turned back on, my time has greatly increased. I will append this post with photos as soon as they are done.
Been around the block a few times today, tried mentalray out of desperation and got amazingi results with the default settings. Then after hours of switching the file over realizied you cannot use RPCs and I need moving people. With the settings I had before,it was taking more than an hour to render. Now I have tried turning off Indirect Illumantion (GI)and got suprising results. Very fast render and not a bad image. I am upping the lighting now and will post tommrow.
thanks for you help.
michael
Yes, I guess a lot of us still waiting for an answer from Archvision considering their RPC being incompatible with MR.. :(
Nice effort Michael, keep it up. Don't forget to save the FG file, so U can re-use it in the animation.
Waiting for an update..
Hi thier answer was that they are waiting for a 3rd party to make/market a plugin.. not very business savy if you ask me.. they said just keep watching the newsletter.. they have no idea when it will be ready.
I have been able to get these to render very quickly using no gi. Will that effect in any way the smoothness of an aniimation? I hope not.
michael
