How to speed up Mentalray 101?
Michael Earley
I have been working with vray for some time with ok results. I have just started a new project and was searching for help about animation in this forum and ran across a thread that said that someone knew someone who had a friend who had rendered a model in vray taking 2 hours and they tried it in mentalral and took 20 min.. I was stuck. thought what the heck.. a new mentalray user is born. It rocks, the output is execlent in 1/5 the time on this model just using the default settings. Now here is where I get greedy. Are there any speed tweeks that are generaly known? I will learn the product as soon as I have a moment.. but are there any shorthcuts?
thanks in advance.
Michael
This was done in about 10 min as opposed to 1 hour plus in vray and did not look half as good. I still have to play with the lighting and would welcome any comments.
That scene took over an hour to render with Vray ???
I've rendered 10 million polygons (trees, buildings, cars, people etc ) in one scene, and it didn't take an hour...
That looks like a pretty simple scene, are you sure you are using it right ?
You could get around that by rendering your people in a separate pass using the scanline renderer. Something along the lines of saving a copy of your scene and assigning a Matte material to everything, putting the RPC people in there, setting the original MR animation as a screen environment and render from the same camera.
Reflection and transparency overlapping/interaction with the RPC people would be tricky using this method, but there's probably ways. If that test render is anything to go by, however, there wouldn't be a whole lot of people being reflected or overlapped by translucent objects.
--Edit--
Oh, as for speeding up Mental ray whilst getting decent antialiasing, these sampling settings seem to work well:
(in the Renderer tab of the Render Scene dialog when MR is the active renderer):
Samples per Pixel: Min=1 Max=16
Contrast: Spatial: RGBA all = 0.1
I have to agree with manta. I think you need to tweak your vray settings. Although it's possible to set vray to render for hours/frame you can tweak the settings and not see a marked difference and render that same image in 10min or less.
Check your GI settings ... if you used it.
