terrain tutorial
Sandro
create splines with elevations, (this will serve as the levels of your terrain) then go to compound objects if your using max or viz, click on terrain and then click on the splines with the highest or lowest elevation to start, and then click on the succeding splines, you will see that you are already forming your terrain. hope this will help. this best done if you have a contour map as the image below the splines.
