jewcifer Posted May 23, 2005 Share Posted May 23, 2005 This is a very warm room I'm making in 3DS Max 6 using Mental Ray. All tips are welcome. Link to comment Share on other sites More sharing options...
Hao La Posted May 23, 2005 Share Posted May 23, 2005 may be u post a bigger render so everybody can see Link to comment Share on other sites More sharing options...
IC Posted May 24, 2005 Share Posted May 24, 2005 That's promising Craig. The lighting is pretty good. I'd concentrate on materials. Your floor tiles look double the size the map wants to be. (Mortar joints are generally about 10mm max) You need to try and pull all the colours and textures together to give a nice overall feel. Look at photos in magazines for reference. Keep at it. Link to comment Share on other sites More sharing options...
jewcifer Posted May 24, 2005 Author Share Posted May 24, 2005 I added an end table with a plant (but I'm not sure on the color of the pot). I have changed the floor in two ways. First, I kept the floor tiles the same size and made the mortar joints smaller. The other option was simply making the floor texture half the size (doubled the tiling). Which looks better? Also, are there any suggestions regarding how to "pull all the colours and textures together". I think they fit quite nicely with eachother, but I am no expert. What can I do to improve on this and still keep the same feel? (pictures are higher resolution than before, just for you, goddam) note: Final Gather is set to preview with no pre-calculations, so there is some quality lost because of that.) Link to comment Share on other sites More sharing options...
szi_zsolt Posted May 24, 2005 Share Posted May 24, 2005 Hi ! In my opinion the first floor tiling is better, but I would use a different map to tile with same colors, because it is somewhat too lumpy for me. Cheers! Link to comment Share on other sites More sharing options...
Ben_T Posted May 26, 2005 Share Posted May 26, 2005 yeah, the tile map is a bit too colourful, and maybe the size of the bumps on your walls and ceiling is a tad too big. otherwise, looks good =D Link to comment Share on other sites More sharing options...
lisaray Posted March 14, 2011 Share Posted March 14, 2011 Buy the best possible conservatory you can afford. Sun rooms are also great for gardeners, since they provide a wonderful showcase room for plants, as well as an optimal growing environment. solarium Link to comment Share on other sites More sharing options...
