aflack Posted May 24, 2005 Share Posted May 24, 2005 I spent all day yesterday working on a file in Max 7 with Vray just as always. Saving the file at regular intervals during the day, I have just tried to go back into the file and it just says loading and never actually opens. It's not even a big file at 2,545kb. Anyone got any ideas on how I can get it to open, I can't afford to loose a whole days work? Thanks Link to comment Share on other sites More sharing options...
STRAT Posted May 24, 2005 Share Posted May 24, 2005 try merging it into another file. Link to comment Share on other sites More sharing options...
aflack Posted May 24, 2005 Author Share Posted May 24, 2005 I left the file to open and after working on a few other things it took an hour and a half to open. It says there are 157621 vertices and 358288 faces. The only thing that is a bit strange in the file is a 20 meter x 5 meter piece of wood with 2000 holes cut in it. I created it by making a rectangle into a spline and then attaching the 2000 small rectangles and extruding it which took about 10 minutes to extrude. If I turned this object into a editable Poly or Mesh would this help? Link to comment Share on other sites More sharing options...
aflack Posted May 24, 2005 Author Share Posted May 24, 2005 They really need to be modelled but the thing is they aren't even circling they are all 100 x 100mm squares so i don't understand why it is taking so long! Just duplicating it takes half an hour. Link to comment Share on other sites More sharing options...
