jared_1978 Posted May 26, 2005 Share Posted May 26, 2005 Hi I have a real issue with a rendering of a building. I have two lights in the scene, the skylight and an omni giving me shadows. The problem is that the shadows appear to be jumping slightly, like they are offset from the model. There are light areas where they should be in shadow. I am posting two images that shows this problem. There areno floating parts of the model everything intersects surfaces and so on. The omni settings have 0.6 intensity, area shadows on, under advanced effects the Affect surface rollout has contrast set at .5 and soften diff. edge: 50. Object shadows have the density set at .8 I have tried removing the skylight to see if this would fix the problem in case the lights were interacting in a strange manner but the problem was still there. Please could someone help. I have to animate around the building so photoshop is not an option. Thanks in advance Jared Link to comment Share on other sites More sharing options...
ksampath Posted May 26, 2005 Share Posted May 26, 2005 hai, check the bias settings in shadow map parameters... reduce it to .1 or .01 it depends on whether your units are in meter, millimeter, feet... sam Link to comment Share on other sites More sharing options...
STRAT Posted May 26, 2005 Share Posted May 26, 2005 or even change the bias to 0 Link to comment Share on other sites More sharing options...
