problem of contrast with Vray
rachelC
A lot of times Vray renders will look washed out, even if not using Max's exposure control. Using Vray's exponential color mapping will add to the problem. I usually use HSV Exponential to keep the colors strong, but always need to do some adjustment in Photoshop no matter what.
are all your different bounce stages set to multiplier of 1. i find that reducing primary bounce to .8 and the secondary bounces to about .5 or.6 gives a bit better contrast. still as already mentioned, i'm trying to find ways of getting stronger contrast.
I had a look at your scene and the only way I could get it to render properly was to merge the building into a new scene and put the model at the proper scale. I converted it to inches. When I merged the scene it was very, very small. This can create all kinds of problems.
It seems fine now, however. Give it a try!
Tony
tried to download your model but i culdnt. Check the enviroment and effects window under rendering (or press 8) if the tint in the global lighning is set to black, put the intensity of your light to 1 instead of .1 and check that global ilumination is turned on, an enviroment in vray is set to 1 and with a good enviroment color, (i use a color between white and very light blue)
