arvind Posted May 28, 2005 Share Posted May 28, 2005 Hi, I have been working on a 3dsmax file for the past few days, and we have to deliver it to the client tomorrow evening. it worked fine till i started rendering it today. wen i render it, it says preparing objects and the progress bar goes to 100% then it gives an application error. i use finalrender stage 1 to render, and everytime it crashes. but wen i give a default scanline render, it goes through smoothly. what do i do to solve this problem as i need render it using finalrender only?? thanks in advance, arvind. Link to comment Share on other sites More sharing options...
DennisHolland Posted May 28, 2005 Share Posted May 28, 2005 Hi Arvind, Think hard about what you've changed or added between this and your last good render. The most tedious tasks for a solution is to hide parts or lights, started with the last ones. Maybe you've add something by a third party tool (or plugin)? Link to comment Share on other sites More sharing options...
anvaraziz Posted May 29, 2005 Share Posted May 29, 2005 no idea much bout final render.. think what changes u made before u get these error.. i mean adding any mesh or any lights,,, did u have a previous save ,, ? one time that helped me Link to comment Share on other sites More sharing options...
abicalho Posted May 29, 2005 Share Posted May 29, 2005 In this case, I'd go to the Final Render webboard and ask questions there. They're much better suited to help you. Link to comment Share on other sites More sharing options...
