Need help with backburner pleaseeeee!
pablo scapi
This is driving me nut!
I recently bought a second machine, so i started to test backburner.
Once solved the inevitable troubles that i knew i was going to have, everything seemed to work fine, i render diferent part of an animation, and even the same image in two strips, all o.k.
But then the other day i couldn´t get it to work, i start the manager in the main comp, but when i start the server in the same machine, it can´t find the manager, (all in the same machine, nº1), if i start server in machine 2 is logs in correctly.
I´m running XP SP2 but was working fine till this, don´t remember if i installed an actualization or not before the problem strated.
Please help.
I allways turn of automatic search but rather type in the IP or computer name of the manager computer. Should not make any difference but I do it just in case..
But first check, as stated above, your firewall settings...
OW/PS: Sometimes the server is opened 2 times... at least I had that with viz2005 and then similar problems occur.... not finding manager etc... Check your task manager...
