a waterfall tutorial
edward80
hello all..this is my 1st tutorial & also my 1st thread in here hope u can keep up with my bad english... :)
1- Reset your Max & go to Create panel > Geometry > Particle systems > Blizzard
http://i2.photobucket.com/albums/y24/edward80/max/1.jpg
2- in the basic parameters choose these settings (you also can choose your own settings)
http://i2.photobucket.com/albums/y24/edward80/max/2.jpg
also change these settings in the Particle generation
http://i2.photobucket.com/albums/y24/edward80/max/3.jpg
3- make another blizzard object & change its settings like this
Basic parameters :
width:85
length:10
percentage of particles:5
Particle Generation :
http://i2.photobucket.com/albums/y24/edward80/max/5.jpg
Now you should have something that looks like this
http://i2.photobucket.com/albums/y24/edward80/max/6.jpg
After that we should add some wind to give the waterfall a realistic look
4- Go to the space wraps icon & choose wind then change the settings like this
http://i2.photobucket.com/albums/y24/edward80/max/7.jpg
then link it to the 1st water fall
5-make another wind with these settings
strength:0,105
icon size: 36,771
& link it to the 2nd waterfall
Now we should start with the Material
6-Press M to open your material editor
change the diffuse color to white,
click on the square next to the Diffuse button & choose particle Age
http://i2.photobucket.com/albums/y24/edward80/max/8.jpg
then choose these settings
http://i2.photobucket.com/albums/y24/edward80/max/9.jpg
after that go the opacity button & click the square next to it
& choose Particle MBlur
http://i2.photobucket.com/albums/y24/edward80/max/10.jpg
apply the material to both of the waterfalls
7-Now..select the 2nd waterfall, right click & choose properties
choose General tab
then at the bottom of the screen on the right you should see Motion Blur settings
http://i2.photobucket.com/albums/y24/edward80/max/11.jpg
Now repeat the last step on the 2nd waterfall & choose these settings
Multiplier:100
image slected
8-hit your render button & you should have something that looks like this
http://i2.photobucket.com/albums/y24/edward80/max/12.jpg
  • 3 weeks later...
My Particle MBlur don't works with the blizzard, and the Max 7.0 User Reference says:
"The particle system must support the Particle MBlur map. Particle systems that support Particle MBlur include PArray, PCloud, Super Spray, and Spray."
Wolfgang
