dual xeon performance
very briefly.
this is the machine i just bought:
2 xeon 2400
1 GB DDR ECC reg.
Quadro4 750XGL 128
i'm currently using Max 5 and either Brazil or Illustrate as renderes.
well, i'd like to know if there is anything i can do to set up the system to get the best performances from the whole stuff.
thanks
thanks a lot strat, i already enabled the HT. i was just wondering if there was anything else to do.
P.S. i'm still using the old public test version of brazil actually.
[ May 22, 2003, 11:07 AM: Message edited by: rivoli ]
Using the same system specs as you have... i had a bit of a slow down when you enable Nvida desktop manager... so be sure its off.
although i have also a bit of problem when enabling radiosity on viz4 my system says "assertion failure" . what i do is i click on the ignore botton then everything goes on back to normal. problem is i cant use network rendering cause the system halts when it loads any file with radiosity solution.
HT on either under win2k server, windows 2003 server, or Windows XP professional.
If you turn it on under Windows 2000 Professional SP2, your performance is shot to hell.
If you " " SP3 it'll just ignore the logical cpu's.
Also make sure to turn SSE ON under the max5 render dialog if your using the default render. Its disabled by default.
  • 11 months later...
What is your experience going from the regular desktop systems that use P4 chips or AMD to a dual Xeon system? Do you see any performance using regular apps or just games and other high end apps? Trying to build something and figure price, and I was going to just build another system...
Going to a dual processor system generally effects....
1) Multi-tasking
2) Rendering
3) Any application which allows for multithreading. (Photoshop for example)
If you do any of these activities, you'll find a dual processor system addictive, and hard to give up.
One of the best combinations I've ever worked at is a dual processor machine, on a dual monitor setup. Everything is fluid and quick, regardless of how many apps are open, or what your doing. You can even assign processors manually, allowing rendering to take place on cpu 2, while you continue working on other activities on cpu 1. Its like two computers in one box.
