Creating mountains "tutorial"
edward80
This tutorial is for creating mountains using the displace modifier...
you should end up with a scene like that
1- go to Create panel > Geometry > plane
& use these settings:
Length :500
Width :500
Length segs :200
Width segs : 200
scale :1
Density :2
2- now from the modify panel choose Displace ( make sure that you've selected Displace NOT Displace Mesh)
Now give the strength an amount of 180
3-Open your material editor
from the Material editor click Get material & choose Mask
4- Press The None button next to Map & choose Noise from the material browser & change those settings:
Noise type : Fractal
Levels : 10
then click Got to parent
Now click the None button next to Mask & choose Mask from the material browser
5- Now click None next to map & choose Noise
& change these settings :
Noise Type : fractal
Low : 0,15
Levels : 10
then click Go to parent
6- press None next to Map & select Mask
7- press the None button next to map & choose Noise from the map browser & change the settings
Hight:0,705
Low: 0,42
Levels: 10
phase : 0,5
8- Now press None next to Mask & choose Gradient from the material browser
Now we're finished from making the material ,all you have to do now is to:
9- click & drag the material you've just made to the button None next to Map in the Displace modifier
Now you should end up with a scence like mine....
Now Try to repeat the tutorial with your own settings ..Good luck
  • 1 month later...
  • 2 weeks later...
