edward80 Posted June 3, 2005 Share Posted June 3, 2005 In this tutorial i will teach you a simple way to create your own realistic clouds with out using any bitmaps. reset your max & lets begin.. 1- Go to Rendering then click Environment then Press M to open your material browser. 2- Press None & select Gradient from the material browser then click ok 3- Now press & drag the None button again (should be called Map#1 Gradient) now , & drop it into a slot in your material editor. a small window should appear select instance then ok 4- in the gradient parameters ( in your material editor) click color#1 & change the colors settings like in the picture below then choose color#2 & also change the colors settings. 5- then change these settings : Gradient type : Radial - Noise Amount : 0,5 Fractal Size : 2 6- Hit your render button & you should have something similar to this Hope that was helpful Link to comment Share on other sites More sharing options...
dexter Posted June 4, 2005 Share Posted June 4, 2005 That's so great edward, thanks for the tutorials... Link to comment Share on other sites More sharing options...
