RAYMOND Posted June 4, 2005 Share Posted June 4, 2005 for viz2005 when i try to create a avi from Ram Player, after the save as the video compression dll comes up for the final options. Not it does not come up at all... then in about 10seconds Viz crashes. apparently viz cannot find the dll or it is corrupted any ideas.. Link to comment Share on other sites More sharing options...
LukeC Posted June 8, 2005 Share Posted June 8, 2005 Im not too sure about your problem, but in the past we have had problems with the ram player running out of memory - which, obviously, is limited to the amount of ram the pc has in it. Maybe it might have something to do with that, sorry if its not much help. Link to comment Share on other sites More sharing options...
RAYMOND Posted June 8, 2005 Author Share Posted June 8, 2005 ussually that is a problem however on this one i can concurrently run viz4 with viz2005 and use viz4 to create the avi that i need..... something went wrong with the viz2005 conponent... Link to comment Share on other sites More sharing options...
Brolloks Posted June 10, 2005 Share Posted June 10, 2005 I've had issues with the RAM player on different PC's although the same version of 3DS Max. I don't think the issue is limited to the amount of RAM on the PC. I've loaded files taking up 2x the amount of physical RAM without issues (apart from getting slower) and on another PC it crashes when it reaches the limit of physical RAM.... Link to comment Share on other sites More sharing options...
