MongoMan Posted June 7, 2005 Share Posted June 7, 2005 hi I need to do some batch changes in max on an imported dwg file I need all the editable splines to be renderable. I m not sure but I t seems as though maxscript is the way to do this the scene has roughly 1700 editable splines in it each named LAYER_1.01 through to LAYER_2.1783 by looking at the max script listener and searching on the net I was able to make a script like this ======================================= select $'LAYER_1.01' $'LAYER_1.01'.renderable = true $'LAYER_1.01'.thickness = 0.025 ======================================= that works but obviously only does 1 object I tried a few ways to do them all in a batch without success this below doesnt work it does select all objects in the scene but doesnt perform the rederable change to them ======================================== select $'LAYER*' $'LAYER*'.renderable = true $'LAYER*'.thickness = 0.025 ======================================== I am aware perhaps that the objects need to be put into an array first etc but I dont really know how to do this the things i have tried dont work. If theres a way to do what i want without a script well thats fine as well thanks for help in advance Link to comment Share on other sites More sharing options...
MongoMan Posted June 7, 2005 Author Share Posted June 7, 2005 ah dont bother thanks to http://www.cgarchitect.com/vb/showthread.php?t=5216&page=1 Abicalho at the bottom of that page .. this works =================================== select $* for i in selection do if hasproperty i.baseObject #renderable do ( i.baseObject.renderable = true i.baseObject.thickness = 0.50 --i.baseObject.DisplayRenderMesh = true ) clearSelection() ======================================= Cheers Link to comment Share on other sites More sharing options...
