OllyNicholson Posted June 7, 2005 Share Posted June 7, 2005 Does anyone else have the annoying problem of ray-traced shadows falling with a gap between where it should start and where it actually does in the render? e.g. a pole interecting into a wall and the shadow projected not starting from the object but a small but significant distance from it, on the surface the shadow lands on? This problem is occuring using the Scanline renderer. Let me know if you have any ideas Olly Link to comment Share on other sites More sharing options...
Victor Erthal Posted June 7, 2005 Share Posted June 7, 2005 Set the ray bias with a smaller value and everything will work just fine. Link to comment Share on other sites More sharing options...
ecastillor Posted June 7, 2005 Share Posted June 7, 2005 Victor Erthal said: Set the ray bias with a smaller value and everything will work just fine. and it will also take longer to render Link to comment Share on other sites More sharing options...
OllyNicholson Posted June 8, 2005 Author Share Posted June 8, 2005 Is this problem occuring as I'm modeling in real dimensions? - e.g. my wall is 2.5 metres high in max - and I know max has problems with small units. I shall try out the ray bias and see if that works O Link to comment Share on other sites More sharing options...
