Creating A Realistic Brick
jar73186
Does Any body have any suggestion or know of any tutorials for creating a realistic brick texture in 3ds Viz. I just started doing architectural models and so far I have not been able to create a realistic brick. All of the materials that I use look like somebody used a crayon and colored them in.
Thanks
Adam
Thanks
Adam
Here's one I've done recently. Was just a combination of some noise, the Max Tiles material, and a bitmap with some texture for the bricks.
Jeff, that's a very nice brick technique. Would you mind sharing more about the settings and images you used? Would probably work great for shingles as well.
i like The Brick "Masonry Designers" so cool
here is a google search result Link for This!
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLD,GGLD:2005-18,GGLD:en&q=%27masonry+designer%22
i believe The guys at Accurate Image Marketing Inc
http://www.accurate-image.com/
are The one who do all These different Masonry designers
Accurate-Image: Belden
http://www.accurate-image.com/belden/help/click.htm
Accurate-Image: MD and Color Builder
http://www.accurate-image.com/essrocvm/zip_code2/main/aim_main.asp
Amce Brick
http://www.acmebrick.com/md/
Belden Brick
www.beldenbrick.com/md_page.htm
FeatherLite
http://www.featherlitetexas.com/home-flt.htm
Henry Brick
www.henrybrick.com/MasonryDesigner.html
McNear Masonry Designer
www.mcnear.com/md_download.html
Metromont Materials
www.metromontmaterials.com/masonry_designer.htm
Potomac Valley and Brick
http://www.accurate-image.com/distributor-version/install/setup.html
RMC Ewell
http://www.rmcewell.com/masonry_designer.htm
Singletary
http://www.singeltary.com/masonry.htm
There are certainly more yet to be discovered
Randy
