jackb602 Posted June 12, 2005 Share Posted June 12, 2005 I've just received several files from a client that were created in AutoCAD 2004. I own AutoCAD 2002 and can't open them. I've also tried demos of two DWG conversion utilities, and they both failed. Would someone be willing to translate them for me? There are four files. Thanks, Jack Link to comment Share on other sites More sharing options...
kippu Posted June 12, 2005 Share Posted June 12, 2005 jack check your pm Link to comment Share on other sites More sharing options...
hlkhl Posted June 12, 2005 Share Posted June 12, 2005 i think you can download a trail version bricscad http://www.bricscad.com install and use "save as" to convert your file to any other autocad version dwg Link to comment Share on other sites More sharing options...
jackb602 Posted June 12, 2005 Author Share Posted June 12, 2005 Thanks for the help guys. I actually had received the files in ACAD 2000 as well, but hadn't noticed the e-mail attachement. So I'm all set. Thanks, Jack Link to comment Share on other sites More sharing options...
TheAllusionisst Posted June 13, 2005 Share Posted June 13, 2005 In the future you may look at 'DWG Gateway', I think it is by Solid works (memory isn't that good) and it installs in your version of AutoCAD (14 and up I believe) and reads and writes from verion 1 to 2004 and it is free http://www.dwggateway.com/ Link to comment Share on other sites More sharing options...
