storage problem
hi people!!
Im thinking on build a storage system for maps, blocks, works, backups etc.
what kind of storage system over network are you using???
i saw a system called fibre channel storage array. what do oyu know about it???
thnaks in advance..
I built an external 500Gb Firewire unit for backups, mp3's, storing video off my camera etc - basically bought the case from these guys:
http://www.specialtech.co.uk
and put a couple of Maxtor 250Gb ATA133 drives in - works pretty well - you can work with the video footage without any problems off the drives and it's heaps faster than backing up over a 100Mb LAN. Cost about £300 ($550 ish) the drives are in removable cages and so far it's been very reliable.
It's not as fast as having drives connected directly to the SATA bus and I don't think you'd gain anything by using 10K drives, but it's plenty fast enough to access files from.
You can also get Firewire 800 units with 4 drive racks - which would be closer to what you're looking for - not sure if they do RAID versions as well. I'd imagine that for a $1000 you should be able to put together a monster setup.
Have a look at the Lacie website for pre built systems (though special tech also do them and are probably way cheaper!)
Hope it helps
Deri
hi people!!
thnaks in advance..
the solution I gave him is $850 for 1 Terabyte so sheaper than your solution, and puts 100MBPS easily. and in addition he gets a warranty. building it by yourself in your case did not save you money and if any problems ocurr you're on your own. now people are going to think I was paid to say that. not at all but it is clear that it is a better less headache solution.
