render in vray
rachelC
i was wondering if someone could point me in the right direction? i am having my 'debut' using vray advance. in the attached scene, I have 1 vray light with a multiplier of 1.2 white to light up the facade. could you tell me how can i get the white render on the facade to look white please?
Many thanks
Have you tried upping the multiplier 1.2 is a bit small for a vray light.
Also make sure the light is facing the model to illuminate it well. If the back roof is being hit the illumination may not be blanketing the right areas.
thank you for all your help. by increasing the vray light to 2.0, i got the following render. Now, i have added a direct light (with ray trace shadow) to my scene as well as the vray light to try to get crips shadows. could someone tell me which settings this light should be for best results please? eg:
the setting in the indirect illumination settings and also general parameters?
In fact, any tips to make the attached image better would be brill.
many thanks,
The default settings are a good starting point with VRay.
Your direct light should be set to VRay shadows not ray trace, never use ray traced anything with VRay.
Here's some starter settings for you:
GI ticked
Irradiance map / Quasi Monte Carlo
Irradiance Map:
-4 -3 everything else default
Environment ticked
Your direct light:
shadows ticked
VRay shadow
colour yellow/orange/white
VRay shadow parameters:
transparent ticked
area shadow ticked
sphere ticked
subdivs 16 ( for straters )
Have a butchers over at
http://www.chaosgroup.com/forum/phpBB2/index.php?sid=0e97b870c57f2ea9d2816eba16efab37
or go to evermotion.org
  • 11 months later...
Hello There.
Well as siliconbauhaus says, you never should set your shadows to raytraced or any other, just Vray Shadows.
I never put any vray light for exterior, i suggest to put that direct light and set the multiplier lower than 1, and just play with the envioronment override multiplier, and of course the Indirect Illumination, allways Irradiance Map, and for second bounces Quasi Monte Carlo
