"thickness" in Lightwave
Hector
Hello:
I was wondering how can I give "thickness" to a shape made of several polygons. Assuming that it is not possible by extruding or bebeling of course.
Say for instance that I have a curved surface and I need to create a "parallel" surface or offset of it.
I would like to be able to control the distance between both survaces(thickness). The polygons that form the edges should be created as well.
Is there any tool or plug-in for this. Lightwave 7.5 or 8.3 ??
Thanks,
Hi Hector,
Doesn't 'Smooth Shift' do just that?
Copy and Paste your object to another layer, Flip the Polygons (press F), then Smooth Shift numerically. This creates a bridge between the old and new polygons and the normals are all facing the right way.
Take these polys back to the original layer and merge the points.
  • 2 weeks later...
I had used smooth shift before but I hadn't figured out that I could use with several polygons at the same time to create thickness.
It seems to work for the shapes I've tested so far.
Thanks
just make sure you use a high angle in the numeric panel,so that the polygons extrude as one block!
