blair Posted June 20, 2005 Share Posted June 20, 2005 I am doing a straight on elevation of a residence and using a pattern fill for the roof shingles and it tiles just fine. But, all tiles are exactly the same width/height as if on a perfectly vertical plane. I have tried the perspective skew tool etc but cannot get the tiles to show perspective. How can you get the shingles to recede to a slightly lesser vertical dimension to express perspective. Link to comment Share on other sites More sharing options...
jucaro Posted June 20, 2005 Share Posted June 20, 2005 Can you post an image of what you intend to do? I'm kinda dense today Link to comment Share on other sites More sharing options...
blair Posted June 20, 2005 Author Share Posted June 20, 2005 I doubt you are dense! It is probably my inadequate description that is the problem. If I upload this graphic correctly perhaps it will help to explain things better. Link to comment Share on other sites More sharing options...
jucaro Posted June 20, 2005 Share Posted June 20, 2005 Is this what you mean? If so, you can: Tranform--->Distort--->Perspective Or Tranform--->Non-uniform Scale--->Perspective Its easier on CS2 if you use the Vanishing Point Tool Hope this helps Link to comment Share on other sites More sharing options...
BrianKitts Posted June 20, 2005 Share Posted June 20, 2005 I haven't played with the vanishing point stuff is cs yet, but a quick comment since you said you are using the pattern fill. If you are doing it as a layer effect, once you make the pattern and tile it with the overlay... you have to raster the layer in order to be able to transform it as mentioned above.... Link to comment Share on other sites More sharing options...
blair Posted June 21, 2005 Author Share Posted June 21, 2005 Thanks Juan and Brian That was very helpful! We have CS1. Is CS2 upgrading real well for everyone? We do not have much in CS1 for CS2 to argue with so I would hope that it would be a smooth install. Is everyone happy with the BRIDGE thing? Link to comment Share on other sites More sharing options...
