AJLynn Posted June 20, 2005 Share Posted June 20, 2005 I have 3DS Max 7 and various updates - SP1 and the 7.5 update (Hair&Fur Extension, Viz Extension and mental ray Extension). What I would like to do is set up machines that don't have a full Max install on them but only mental ray 3.4, so they can run the raysat service and be "satellites" in a DBR environment. The documentation seems to hint that this ought to be possible, but I can't find anything that tells me how to do it given the discs I have. Does anybody know about this? Link to comment Share on other sites More sharing options...
abicalho Posted June 20, 2005 Share Posted June 20, 2005 You can only do that if you have mental ray standalone. It seems like you do not, so you have to install MAX 7.5. Link to comment Share on other sites More sharing options...
AJLynn Posted June 20, 2005 Author Share Posted June 20, 2005 abicalho said: You can only do that if you have mental ray standalone. It seems like you do not, so you have to install MAX 7.5. They do make it hard on us, don't they. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 20, 2005 Share Posted June 20, 2005 you can script install 3dsmax and updates with a batch file. all you do is run the batch and walk away. everything installs, and is ready to go. Link to comment Share on other sites More sharing options...
abicalho Posted June 20, 2005 Share Posted June 20, 2005 AJLynn said: They do make it hard on us, don't they. It's not hard, it's logical. If you have Distributed Rendering from one renderer, you need that renderer - you either get the renderer as a standalone app or the renderer as embeded in the app. Honestly, setting up mental ray standalone is a nightmare, has always been, and it's something that doesn't come from Discreet. Setting up MAX 7.5 for Satellites is as simple as hitting 1/2 dozen buttons in an Install dialog. Nothing else. Pick your choice. Link to comment Share on other sites More sharing options...
