edward80 Posted June 23, 2005 Share Posted June 23, 2005 hello all i've imported a dwg file to max but whenever i try to import / merge another model it doesn't appear in the viewport or layers though i can move it ! also if i try to create a box from max it also doesn't appear tho i can see its parameters in the modify panel ..any help to fix this will be appreciated.. & here is a screenshot of the problem.. Link to comment Share on other sites More sharing options...
JamesTaylor Posted June 23, 2005 Share Posted June 23, 2005 Have you checked that all layers are visable / unfrozen in max? like you say it seems to be creating the elements Link to comment Share on other sites More sharing options...
edward80 Posted June 24, 2005 Author Share Posted June 24, 2005 thanx for your reply...but i checked it ..all layers are visible & non of them are on freeze am afraid i have to re-install max ..this problem never occured before Link to comment Share on other sites More sharing options...
Tim Nelson Posted June 24, 2005 Share Posted June 24, 2005 Maybe your units are not set right and the box is super small compared to the house? I doubt it, but just a thought. Link to comment Share on other sites More sharing options...
abicalho Posted June 24, 2005 Share Posted June 24, 2005 2 whats? You don't have a Display Unit, to it's impossible to compare that with the size of the house. It could be 2mm, which then would be perfectly right. Link to comment Share on other sites More sharing options...
