mhinks Posted June 27, 2005 Share Posted June 27, 2005 Hi guys, Im fairly new to compositing layers for outside renderings, having usually tryed to get the single frame as close as poss. Im rendering building, bg, trees, people as seperate layers to put together in Photoshop. Im using RPC people, cars,and trees, and rendering them out and saving the alpha. But when I put them in top of the building scene render, there is a white boarder around the content. How do you best composite RPC's back in to your scenes? Kind regards Link to comment Share on other sites More sharing options...
JamesTaylor Posted June 27, 2005 Share Posted June 27, 2005 try flattening the alpha into the layer and then in photoshop go: layer menu - matting - defringe. it should get rid of the white boarder Link to comment Share on other sites More sharing options...
mhinks Posted June 27, 2005 Author Share Posted June 27, 2005 Beautiful. Just the job! Can you recommend any aother tricks for adding RPC's. I thought maybe render them all at 100 illum, so you have the most colour to start with and match them in after? Link to comment Share on other sites More sharing options...
Bugga_Guy Posted June 27, 2005 Share Posted June 27, 2005 When you render out the RPC in max make sure your environment is black, or the colour that is of the image (ie blue - blue sky) Link to comment Share on other sites More sharing options...
