digi_archi Posted December 19, 2003 Share Posted December 19, 2003 I am using Radeon 9700 Pro and I am just using it's default setting. Is there better setting or better driver to run Max and CAD? I only get up to 75 Hertz as screen refresh rate. I thought I could get up to 85 Hertz or something. Please help. Thanks. Link to comment Share on other sites More sharing options...
Greg Hess Posted December 24, 2003 Share Posted December 24, 2003 Maximum hertz is determined both by your video card and your monitor. If your hertz only goes up to 75, try reducing the resolution your working at. Then of course, if your working on an LCD with a DVI-I connection, hertz really doesn't have much meaning to begin with. What monitor are you using? Link to comment Share on other sites More sharing options...
digi_archi Posted December 24, 2003 Author Share Posted December 24, 2003 Thanks Greg. I am using Sony CPD-G520. I have one more question about monitor. I get these two fine line across the monitor. They are running horizontally and very thin. Probably one pixel. How can I get rid ot them? Link to comment Share on other sites More sharing options...
bigcahunak Posted December 24, 2003 Share Posted December 24, 2003 Originally posted by digi_archi: Thanks Greg. I am using Sony CPD-G520. I have one more question about monitor. I get these two fine line across the monitor. They are running horizontally and very thin. Probably one pixel. How can I get rid ot them? You cant. Thats how the bigger CRTs are built. For big monitors, having the tube cover the whole field in one pass is just two much. The tube devides it to 3 areas and what you see is the border between them. Get an LCD... Link to comment Share on other sites More sharing options...
Greg Hess Posted December 24, 2003 Share Posted December 24, 2003 Biga is both correct and incorrect... Not all monitors are built the same way. The two lines are a symbol of a triniton display. Trinitrons use a technology know as aperature grill's as opposed to an invar shadow mask. Of course this is probably hella confusing, but I'll just go and post an answer for you . http://computer.howstuffworks.com/question406.htm Link to comment Share on other sites More sharing options...
