Jeff Mottle Posted August 14, 2003 Share Posted August 14, 2003 Just thought I'd let everyone know about a small but powerful app I have been testing for the last month to do my daily backups and just purchased today. As I know most of you do backup directly to disk I think you will find this to be a pretty nice app. It's called Backup Magic http://www.moonsoftware.com/bmagic.asp It bascially does a file copy of your files and you can do drive mirroring, incrmental backups (something most file copy utilities can't do) as well as full backups (non-locked files only). I have mine set up to do daily incrmental file backups to an external HD using the archive flags in windows and a weekly full backup to a single directory where everythign is overwritten each week to create a single backup off all of my files. It also have the ability to do dynamic directoty naming. So each day the directory structure of my changed files will appear under a folder names by the current date and time. The scheduling is all run from windows scheduler (as the app can be called from a command line) and you can also have the program run apps before and after the backup. In my case I have a batch file that calls a few scripts to close oulook and kill any resident processes, do the backup, then re-open Outllok again once it's done. You could also call a program to shutdown windows once it's done. Anyway I've tested about a dozen app like this over the past year and none have been as good or reliable as this one, and for $20, you can't go wrong. If you want a very reliable and powerful set and forget backup app...take a look at this one! Link to comment Share on other sites More sharing options...
Greg Hess Posted August 15, 2003 Share Posted August 15, 2003 Jeff, Thanks much for the link! I'm always on the outlook for cheap effective programs . Not to hijack the thread...but here's a few of the ones I've found useful. Diagnostic: 1) Memtest www.memtest86.com (Used to diagnose memory) 2) Sisoft Sandra www.sisoftware.co.uk (Stress testing/System Diag) 3) 3dmark 2001 SE www.futuremark.com/download/?3dmark2001.shtml (Stress Testing/Video Diag) Repair/Recovery: 1) File Recovery 2000 Pro www.bitmart.net/r2k.shtml (Restoring Lost Files) 2) Spinrite www.grc.com/spinrite.htm (Repairing Bad Sectors) 3) Norton Ghost www.symantec.com/sabu/ghost/ghost_personal/ (Cloning Drives, Saving a Failing Drive, Image Backup) 4) Partion Magic www.powerquest.com (Moving/Recovering/Changing Partions) There is more, but thats all I can think of right now. Quick note on these...File Recovery 2000 Pro has recovered over 26 gigabytes of lost data so far this year. Including one drive that was formated AND repartioned. Link to comment Share on other sites More sharing options...
Jennifer Posted August 15, 2003 Share Posted August 15, 2003 Hi, Backup Magic and Restorer look like great products. One thing that I use all the time is called FileSync from FileWare. It allows you to specify a date range and filter, and I use it to backup my recent work to a USB harddrive when going between home and work computers. I also use it to quickly copy my student's work from their disks to my drive. Diskeeper for automated defragmentation is another useful utility. Executive Software. Partition Magic is an essential, also. Link to comment Share on other sites More sharing options...
xgarcia Posted August 22, 2004 Share Posted August 22, 2004 I've been using PerfectDisk 6.0 for defragmenting. It will do "smart placement" defrag - places files on the disk platters according to frequency of use (read: access files faster). Also it will defragment boot files before windows loads. Check out the demo. Link to comment Share on other sites More sharing options...
