Michael Earley Posted June 29, 2005 Share Posted June 29, 2005 I have tried to set a key at different to simulate a sunset. I have tried to make a key at 0 with a intensity of 3 and then a key at 100 at 2 / 200 at 1 and change the color a little and then 300 at 0. When I change one.. they all change, I thought this is how i used to do it in Viz? any help would be great! Michael Link to comment Share on other sites More sharing options...
gatino Posted June 29, 2005 Share Posted June 29, 2005 I have tried to set a key at different to simulate a sunset. I have tried to make a key at 0 with a intensity of 3 and then a key at 100 at 2 / 200 at 1 and change the color a little and then 300 at 0. When I change one.. they all change, I thought this is how i used to do it in Viz? any help would be great! Michael I don't know how you set the keys, but I think you should try to reset them to see if it happens again. Otherwise, go in the track view-curve editor window, in the sun/object/multiplier and correct it from there by editing the curves. (you can do the same for the color or any other property). Link to comment Share on other sites More sharing options...
lambros Posted June 29, 2005 Share Posted June 29, 2005 though I am not quite sure, have you activated the AutoKey set mode? Has the viewport frame changed to red? Link to comment Share on other sites More sharing options...
