Modelling using Microstation J/V7
dexter
This is my new project... I modeled it using Microstation J. I have a problem with my gutter & mouldings, they went missing when I imported them in max, only the upper & lower rims remain...I made a profile of the mouldings using a combination of circles & lines and then extruded them...don't know what went wrong here...anybody knows what happen here?...
Thanks...
  • 11 months later...
Rememer, NO SURFACES IN MS...that includes B-Splines. You want to use only solids to bring over to MAX.
Turn on 2-Sided as indicated to fix it or go back to MS and covert the gutter to a "smart-solid".
Also watch your use of the mirror comand in MS...I know it is a pain to try and avoid it, but it will cause a flipped normal in MAX and cause this problem.
Good Luck...
