only3d Posted July 11, 2005 Share Posted July 11, 2005 hi 2 u all ive had this problem a few times before but i solved it by reloading the relevant folders but this time nothing works! i even re-installd the soft' and it seemed fine untill i opened the file i was working on beforehand plz help its really frustrating! p.s.- the materials folder is fine and in its place. nothing missing or something like that tnx in advance Link to comment Share on other sites More sharing options...
Ace_Face Posted July 12, 2005 Share Posted July 12, 2005 Your explanation isn't very concise. I would guess that if you are creating custom materials and have textures applied to the material and you are missing the textures. Then the library is not loading. First you should make sure the textures are located in one of the libraries you are loading for the file. Then open Library Manager and delete the libraries and find them through the Local/LAN tab to make sure they are pathed properly. Link to comment Share on other sites More sharing options...
only3d Posted July 15, 2005 Author Share Posted July 15, 2005 Hi tom and tnx 4 your reply, but as i said before im possitive its not a folder location library or something similar. 1st- its not a custom material im having problems with but with all materials of all objects! 2nd- i re-installed the soft' so that was supposed to take care of that in any case, wouldnt it? 3rd- i tried loading and re-loading again & again (u like metallica by any chance? ) and nothing helps so waht m i missing? and if i can shed more light then tell me and ill try Link to comment Share on other sites More sharing options...
Ace_Face Posted July 18, 2005 Share Posted July 18, 2005 Materials are loaded on a per file basis. Do you get this problem with all files or just one specific file? If it's one file, then use the attribute manager to import materials from another file that contains the ones you are missing. Link to comment Share on other sites More sharing options...
