I need help for rendering of a line
Damyanov
Hi guys,
I am importing a DWG in 3D MAX. I have to render some lines. I put the renderable option of the line, but in the render window it looks more with circle section than with rectangular.It seems to be ... oversmoothed. Where can i found the way to make it to look right?
Thank you all in advance!!!
In the latest version of Max, you have the option, when rendering a line to choose between a circle or rectangular line render. under the line rendering options. Not sure which version this began in.
munz
select a line...then on the rendering rollout...check renderable and display render mesh...on the set the "sides" to 4, and the "angle" to 45...that should make a perfectly square line render apply a smooth modifier then uncheck everything in the mod.....works in all versions of max he he he
