Tim Saunders Posted July 11, 2005 Share Posted July 11, 2005 any thoughts on why it is completely black inside the front window here? i have like 8 photometric 75watt free point lights inside the room. the glass is a standard material, 2 sided, opacity of 30, specular-45, glossiness-65, reflection-30 with fallof/raytrace valued at 60. Link to comment Share on other sites More sharing options...
Fernando Lino Posted July 11, 2005 Share Posted July 11, 2005 use more reflection...in properties turn receive and generate shadows off Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 11, 2005 Share Posted July 11, 2005 more info... software, render engine, ect... ...are you normals flipped towards the interior? Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 11, 2005 Author Share Posted July 11, 2005 staight viz 2005 scanline. it shouldn't matter if normals are flipped if it is a 2 sided material should it? the glass is only an extruded line, no depth to it. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 11, 2005 Share Posted July 11, 2005 if you turn off the glass, does the inside render lit? Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 11, 2005 Author Share Posted July 11, 2005 i don't even see the lights if the winsow is deleated. i checked and the lights are turned on. maybe i just need to use a different light. i'm stumped. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 11, 2005 Share Posted July 11, 2005 do photometric lights work with scanline? Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 11, 2005 Author Share Posted July 11, 2005 do photometric lights work with scanline? yeah. i'm using radiosity too. i just made a new glass material and applied it, reset the radiosity and it rendered fine. something was funky with the material. thanks everyone. Link to comment Share on other sites More sharing options...
Brian Cassil Posted July 11, 2005 Share Posted July 11, 2005 Can you post an update Tim? Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 11, 2005 Author Share Posted July 11, 2005 Can you post an update Tim? yeah, still not finished, but i'm passed the glass problem (for now). I may play with the reflectancy and opacity once i get some more background type stuff in the reflection. i think it may be a bit too reflective now. we'll see. Link to comment Share on other sites More sharing options...
STRAT Posted July 12, 2005 Share Posted July 12, 2005 really the key to nice looking glass is to have some sort of internals modelled and lit showing through. else you just got a dark mirror there. Link to comment Share on other sites More sharing options...
