3dsmax rendering error
jijasa
Hi
I have problem in 3dsmax rendering with rpc. (already i have posted rpc bitmap filter error. Somebody suggest to switch on the billboards in the rpc. It was make my render fast.)
Also I have an another problem in night shot rendering.The error shows
1.Insufficient memory for shadows Buffer for Litght "Omni 79". (Also the error shows to some of my lights with shadows).
2.There was an error loading diffues texture data from the following RPC file:
Thread b9cd:
--JPegAccessor::loadJPeg: The JPeg library encountered an error while processing a JPeg
--Texture::data: ERROR while retrieving RGB data for image 0 0
3.3ds max application has encountered a problem and needs to close. We are sorry for the inconvenience.
Can you help me.
Thanks
Regards
Jija
Hello,
I saw in your other post that you have a decent configuration, so did you activate the /3GB switch in Windows XP ?
How big is your scene and your jpgs (don't forget that they get uncompressed at rendertime)?
These informations could help some figure out ways to help you out.
maybe one of your model might be damage or corrupted try to locate and remove it from your scene or remodel and merge it again....it may solve your problem. i had the same problem 3 weeks ago.
Regards
