maurocan Posted July 12, 2005 Share Posted July 12, 2005 hi everyone... does anyone know how to create a fire effect on a still render using VRAY and max 5 ??? i just cant find it out. thanks a lot. Link to comment Share on other sites More sharing options...
Richard McCarthy Posted July 13, 2005 Share Posted July 13, 2005 Many ways, but how does this relate to real-time CG?? You can use the easy way, using 2D clip map of sequence/movie of fire (Artbeat I believe have put out a nice package of that, check http://www.artbeats.com) The clipmap technique also works in most situation in (even in VRay) Real-time CG too. As long as the 3D engine supports transparent clipmap and sequences. Another way to do it is to use particle (Max built in, or you can try from same maker of VRay "Aura" - http://www.chaosgroup.com/software/aura/ - mind you it is currently in closed beta stage) to simulate fire as particle. I am not much of a particle buff, so I wouldn't know that, but check Max Manual for that. The same can be done in real-time as long as engine supports particles (which most do nowadays) Link to comment Share on other sites More sharing options...
