mapping onto "transparent" signage
vizwhiz
hi There
i am missing something i didnt Think This was This elusive
how do you add a "Text" mapping onto a "transparent" sign ?
i am using as a "place-holder" to located The Logo Image
The tga map has a transparent background
i have Tried "mask" and adding The tga map To The opacity channel
of The sign object, etc efforts have been more Than useless
so far This isnt working as i eagerly anticipated
any help would be more Than greatly appreciated
any other comments also greatly appreciated
Thanks
Randy
The White Vizard
some success
i used arch materials for The 1st Time ever
and surpise They worked easier Than i realized
here is update
Next Question, are There are generic setting for using Mental Ray
to make This small simple project look a lot better Than scanline?
i am going to do a "walk-around" of This sometime Tomorrow
100 frames for iball Points of View, but Too large for animation
on purpose, This is a great design review Tool
for This project 1200x400 works just fine so far
The client really likes This 360 spin-around
Thanks
Randy
MR
Sky dome-multiplier .75 +/- 216,227,255. You may want to desaturate that a bit for a "bright" sunshiny kind of day. Typically that's a good starting point. Using hex conversion of HSV 213 (degrees),.1,1.00.
Direct target, shadows raytraced-light effects shadow. Multiplier of 1 you may have to adjust that because your materials where not created under that level of lighting intesity. Color 255,252,248 or better yet hsv in max 23-24 H, 5-10 S, 255 V. You can add the 'Arizona' bright sun effect by adjusting the hue up into the yellows just a touch.
FG-
I'm running Max 6 so....
samples can range from 250-2500+. When palyin' with the lights keep the samples low 50-100. Once the lights are cool (or warm for daylight LOL) use the measured sample radius. Your scene could use as low as .5' max setting, but don't think anything above 2' will give good results. You want to speed things up a bit use something around 1/10 to 1/4 of the max rad in the min radius.
The thinking with the max radius being you want the GI to be able to effect smaller areas than the default radius (1/10 of the overall scene). For your scene the glazing inset into the veneer is about the LOD needed. A 3' radius does not really give the fine detial that a .5' or .25' radius will yield. You can still get decent detial with default settings and super duper high sampling, but there is some sacrifice-the scene tends to wash out a bit and render times can climb through the roof.
My guess is that you could get good results at about 500 samples with .5 max and .125 min with real good render times 1-2 mins 800x600, 10-15 mins 2400x1800 on a single p4 3.0 HT with 2 gig of ram, but don't quote me on that ;)
Hope it makes sense and is of some help
WDA
