Msamir Posted July 13, 2005 Share Posted July 13, 2005 I'd really appreciate if someone tried and textureed the chair in this max v6 file with the maps attached ,i'm finding some difficulties texturing it ,actually its the bump map that is causing my pain ,at first it didnt work but after increasing the value more than 100 and changing it to rgb mode it gave really strange results. Thanks in advance Link to comment Share on other sites More sharing options...
ihabkal Posted July 13, 2005 Share Posted July 13, 2005 salam mazen, I think maxwell doesn't work with bump maps yet... Link to comment Share on other sites More sharing options...
hidalgoserra Posted July 13, 2005 Share Posted July 13, 2005 wrong! it works and pretty well in my opinion. first try to use .bmp images other type doestn work pretty well. second control (just in case) the the image is grey scale and that it has enough contrast. cheers Link to comment Share on other sites More sharing options...
Msamir Posted July 13, 2005 Author Share Posted July 13, 2005 Hidalgo i did a search on the maxwell forums and they always advised that the bump map should be in RGB mode not grey scale ,i'll try and use .bmp image Link to comment Share on other sites More sharing options...
dave davidson Posted December 20, 2005 Share Posted December 20, 2005 yes bumps work with jpgs and in RGB(not greyscale) also in cinema 4d JPG dont work only jpg, just incase Link to comment Share on other sites More sharing options...
polop Posted December 21, 2005 Share Posted December 21, 2005 works fine for me: here's zipped scene with textures (from VIZ 2006): http://rapidshare.de/files/9563270/scene.zip.html Bump map adjusted, texture mapped oversised for better view. ;-) CU -polop- Link to comment Share on other sites More sharing options...
Trick Posted December 21, 2005 Share Posted December 21, 2005 ...-polop- Is polop "the one" your real name ? Link to comment Share on other sites More sharing options...
Msamir Posted December 21, 2005 Author Share Posted December 21, 2005 Hehe thanks polop that was 4 month ago i got it to work, thanks anyway . Link to comment Share on other sites More sharing options...
