quizzy Posted July 20, 2003 Share Posted July 20, 2003 I have a problem with my network, it disconnects every hour or so, just for a couple of seconds. Anyone had this problem before?? I'm running a 100MBPS network through a switch on WIN2K with SP4 Link to comment Share on other sites More sharing options...
Greg Hess Posted July 21, 2003 Share Posted July 21, 2003 Quizster... Can you give us some info on the network? Is it just some pc's hooked into a 100mbit switch? What company makes the switch? Are you running a inet sharing system with a router? What type of router? Are all the pc's SP4...or do some have different OS's... Link to comment Share on other sites More sharing options...
quizzy Posted July 21, 2003 Author Share Posted July 21, 2003 okay here's the info; 2 pc's with win2k sp4 (fully updated) one switch, belkin one router, draytek the router is connected onto a seperate Network card in one of the two pc's. but the network connection that gets lost is the LAN card.. on that same pc with the two cards in it.... hope this helpd Link to comment Share on other sites More sharing options...
quizzy Posted July 21, 2003 Author Share Posted July 21, 2003 and a picture: Link to comment Share on other sites More sharing options...
siliconbauhaus Posted July 21, 2003 Share Posted July 21, 2003 errr...whats the switch for? why not just run both through the router? Link to comment Share on other sites More sharing options...
quizzy Posted July 21, 2003 Author Share Posted July 21, 2003 thats not my question.... Link to comment Share on other sites More sharing options...
William Alexander Posted July 22, 2003 Share Posted July 22, 2003 Quizzy, Try trouble shooting by disconnecting the other network connection and see if you still have the same problem. If possible. That might be a starting piont to see if it's w2k or on the other side. That's a different switch & router configuration? I assume it's for access to two diffent networks. rgrds WDA Link to comment Share on other sites More sharing options...
