cinebench 2003
hi cga'ers
orininally posted in the cinema 4d forum, but i thought why not in the general forum?
it's Maxon's rendering/graphics card bench tester.
why not down load it and pit your computer's whits against the rest?
you dont need cinema 4d to use it, (well im almost sure, so i've been told) just down load it, start it up and press START :)
you can download it here -
http://www.maxon.net/index_e.html
just one more thing, can you also post up the scene render times in seconds too, only it makes life easier :)
[ March 29, 2003, 09:27 AM: Message edited by: STRAT ]
Date 3/3/03 CINEBENCH 2003 v1
Tester : Paul Griger
Processor : Dual AMD 2000+ MP
MHz : 1.67
Number of CPUs : 2
Ram : 1G
Operating System : Win 2K SP2
Graphics Card : Nvidia GeForce 4 Ti4600 bios: 4.25.00.27.32
Resolution :
Color Depth :
Rendering (Single CPU): 209 CB-CPU
Rendering (Multiple CPU): 389 CB-CPU
Multiprocessor Speedup: 1.86
Shading (CINEMA 4D) : 214 CB-GFX
Shading (OpenGL Software Lighting) : 897 CB-GFX
Shading (OpenGL Hardware Lighting) : 1272 CB-GFX
OpenGL Speedup: 5.94
I await my humiliation from your new system Strat ;)
BTW, the CG Talk group posted their tests here:
http://www.cgtalk.com/showthread.php?s=&threadid=46752&perpage=15&pagenumber=1
best,
paul
Hi Strat,
Here's my setup:
Power Mac G4 Dual 1 GHz ("mirrored drive doors")
768 MB RAM
ATI Radeon 9000 Pro
OS X 10.2.4
and my results...
C4D shading: 121
OpenGL software shading: 322
OpenGL Hardware shading: 484
OpenGL factor: 4.00
Raytrace (single CPU): 96
Raytrace (dual CPU): 174
dual speedup factor: 1.81
I just got my copy of C4D about 2 weeks ago, and I'm really liking it. Your radiosity tips have helped too. I'll start posting images in the next couple of weeks for some critiques.
Jack
guys, can we also put the rendering scene time in minutes and seconds too? only the values given i dont understand, they're certainly not in seconds.
[edit]
Paul, why not change ur resolution from 1280x1024 over to 1280x960? only this will give you a 1.333 ratio renders come out at.
[edit]
I'm not sure what the unit is, but higher = better. :D
Maybe it Gigawatts? "1.21 GIGAWATTS!!!"
My LCD screen is optimized at this res. Any other res and I don't get the full bennys of the LCD DVI hook-up. :shrug:
As Strat has suggested, this new measurement in Cinebench is a little confusing. I've been using Cinebench for several years on many machines and had developed a very good sense of estimation with it. P3s and P4s were approx Ghz X 10. G3s and G4s were Ghz X 13. The new scale throws everything off. Its a little less than 10 X in raytracing though vs the older versions. This shouldnt be the case since the new engine is 20% fatser. My dual Athlon scores around 36 on the old scale and around 350 on the new scale. Oh well, I guess we just have to get used to the new measurements.
Oh yeah, the UPS guy tried to deliver V8 today so I should have it tomorrow :D
CINEBENCH 2003 v1
Tester : Steve Leworthy
Processor : IBM Intelli Station
MHz : 2.66 Xeon
Number of CPUs : 2
Operating System : XP Pro
Graphics Card : nvidia quadro4
Resolution : 1280x960
Color Depth : 32 bit
Rendering (Single CPU): 267 CB-CPU - 1 min 38 secs
Rendering (Multiple CPU): 572 CB-CPU - 46 secs
Multiprocessor Speedup: 2.16
Shading (CINEMA 4D) : 273 CB-GFX
Shading (OpenGL Software Lighting) : 1167 CB-GFX
Shading (OpenGL Hardware Lighting) : 1210 CB-GFX
OpenGL Speedup: 4.44
[ March 28, 2003, 07:50 AM: Message edited by: STRAT ]
CINEBENCH 2003 v1
Tester : Michiel Quist
Processor : P4 DELL
MHz : 1700
Number of CPUs : 1
Operating System : Win2K
Graphics Card : Nvidia GeForce2 MX
Resolution : 1280*1024
Color Depth : 32bit
Rendering (Single CPU): 147 CB-CPU 170 secs
Rendering (Multiple CPU): --- CB-CPU
Shading (CINEMA 4D) : 160 CB-GFX
Shading (OpenGL Software Lighting) : 674 CB-GFX
Shading (OpenGL Hardware Lighting) : 693 CB-GFX
OpenGL Speedup: 4.34
CINEBENCH 2003 v1
Tester : ts
Processor : IBM IntelliStation
MHz : 2ghz xeon
Number of CPUs : 2
Operating System : win 2000 pro
Graphics Card : NVIDIA GeForce4 Ti 4600
Resolution : 1280x1024
Rendering (Single CPU): 197 CB-CPU - 2 min 13.9 sec
Rendering (Multiple CPU): 363 CB-CPU - 1 min 12.6 sec
Multiprocessor Speedup: 1.84
Shading (CINEMA 4D) : 184 CB-GFX
Shading (OpenGL Software Lighting) : 809 CB-GFX
Shading (OpenGL Hardware Lighting) : 986 CB-GFX
OpenGL Speedup: 5.36
CINEBENCH 2003 v1
Processor : P3 Dell
MHz : 1000
Number of CPUs : 1
Graphics Card : Matrog G450
Resolution : 2048x768
Color Depth : 32bit
Rendering (Single CPU): 108 CB-CPU 243 secs
Shading (CINEMA 4D) : 113 CB-GFX
Shading (OpenGL Software Lighting) : 320 CB-GFX
Shading (OpenGL Hardware Lighting) : 149 CB-GFX
OpenGL Speedup: 2.84
CINEBENCH 2003 v1
Tester : Greg Hess
Processor : Athlon 1800+ XP
MHz : 1530
Number of CPUs : 1
Operating System : Windows 2000
Motherboard : ECS K75SA
Ram: 512 Megs of Mushkin PC2700
Rendering (Single CPU): 192 CB-CPU (137 Seconds)
More streaming in. Hehe abuse of power.
[ March 31, 2003, 10:19 AM: Message edited by: Greg Hess ]
CINEBENCH 2003 v1
Tester : G Man
Processor : Dual G4 (DDR)
MHz : 1000
Number of CPUs : 2
Operating System : OS 10.2.4
Rendering (Single CPU): 94 CB-CPU (279 Seconds)
Rendering (Multiple CPU): 162 CB-CPU (160 Seconds)
Multiprocessor Speedup: 1.72
[ March 31, 2003, 10:25 AM: Message edited by: Greg Hess ]
Greg... i am running the same motherboard as you (ECS K75SA)on my home computer. my cpu is a athlon thunderbird 1.4ghz. the processor and the motherboard both support a 266 front side bus, but when i change the setting for the motherboard in the bios to 266 my machine will not boot. it booted once for about two minutes with this setting, then crashed. instead i have to run at a 200 front side bus, which knocks my processor down to 1ghz speed wise. i tried contacting ecs about the problem several times (both phone and email), but they have the worse support i have used. i bought the board when it first came out, and i have not tried to flash the bios with an update. i don't want to try that, unless i know it will work. anyway, i was wondering if you had a similar problem, or if yours worked correctly straight out of the box. i know several people on their web board were complaining of a similar problem. i am not to worried about it, since it was only a $60 board, but it would be nice if it worked correctly.
any advice?
ts.
Originally posted by Greg Hess:
I'll rerender to get seconds. Re rendered and added seconds. Also moved crazy's post to the hardware section.
Ah well that didn't work...so strat when u get a chance, move his post to the technical/hardware section please.
which post? gimme URL
CINEBENCH 2003 v1
Tester : G-tastic
Processor : Athlon 2400+ XP
MHz : 2000
Number of CPUs : 1
Mboard: Asus A7N8X (The Nforce2 One)
Mem: 512 PC3200 Corsair XMS (Not DC-DDR)
Rendering (Single CPU): 240 CB-CPU (109.5 Seconds)
CINEBENCH 2003 v1
Tester : G-man
Processor : Athlon 2200+ XP
MHz : 1800
Number of CPUs : 1
Mboard: Nforce2
Ram: 512 Mushkin PC3200 DDR
Rendering (Single CPU): 217 CB-CPU (121.3 Seconds)
CINEBENCH 2003 v1
Tester : G...tired G.
Processor : Pentium IV Northwood
MHz : 2400 (533)
Number of CPUs : 1
Mboard: Abit BD7-II Raid
Mem: Mushkin PC3000 512
Rendering (Single CPU): 240 CB-CPU (109.6 Seconds)
CINEBENCH 2003 v1
Tester : Greg
MHz : 2660 (533)
Number of CPUs : 1
System: Shuttle SS51B XPC
Ram: Corsair XMS PC3200
Rendering (Single CPU): 263 CB-CPU (100.1 Seconds)
CINEBENCH 2003 v1
Tester : Greg
Processor : Dual Athlon 1900+ MP
MHz : 1600 x 2
Number of CPUs : 2
Motherboard: Asus A7M-266D
Ram: 2x 512 Mushkin PC2100 Registered ECC
Rendering (Single CPU): 202 CB-CPU (130.4 Seconds)
Rendering (Multiple CPU): 373 CB-CPU (70.5 Seconds)
Multiprocessor Speedup: 1.85
CINEBENCH 2003 v1
Tester : Greg
Processor : Boxxtech S5i
MHz : 2x 2800 Xeon (533)
Number of CPUs : 2
Operating System : Windows XP (HT DISABLED)
Motherboard: Supermicro X5DAE
Ram: 2 x 1024 Meg PC2100 Registered DDR
Rendering (Single CPU): 281 CB-CPU (93.6 Seconds)
Rendering (Multiple CPU): 525 CB-CPU (50.1 Seconds)
Multiprocessor Speedup: 1.87
[ March 31, 2003, 04:37 PM: Message edited by: Greg Hess ]
CINEBENCH 2003 v1 ( I added Quadro Data)
Tester : Greg
Number of CPUs : 4
Operating System : Windows XP (HT ENABLED)
Mboard: Supermicro X5DAE
Ram: 2 x 1024 PC2100 Registered ECC
Video: Quadro 900XL
Rendering (Multiple CPU): 597 CB-CPU (44.1 Seconds)
Multiprocessor Speedup: 2.12
Shading (CINEMA 4D) : 283 CB-GFX
Shading (OpenGL Software Lighting) : 1266 CB-GFX
Shading (OpenGL Hardware Lighting) : 1960 CB-GFX*
OpenGL Speedup: 6.91
*=About 1.7 million polys/sec
[ March 31, 2003, 04:49 PM: Message edited by: Greg Hess ]
