Munz Posted July 13, 2005 Share Posted July 13, 2005 I am doing a night shot and I would like to give several of the objects/lights a glow. does anyone know if I can make an object glow or a material glow? I am using max 7.5 thanks Link to comment Share on other sites More sharing options...
Damyanov Posted July 14, 2005 Share Posted July 14, 2005 Hi , I don't know if there scholud be a difference bitween MAX 6.0 an MAX 7.5 in it, but check this out. http://www.skillreactor.org/cgi-bin/index.pl?vpost You'll get a glow in 15 minutes ot less Link to comment Share on other sites More sharing options...
shan Posted July 14, 2005 Share Posted July 14, 2005 hi, you could get the glow effect either by setting up an objetc ID and applying Effects > Lense > Glow set for corresponding object ID or by setting up an effects ID to the material and applying Effects > Lense > Glow set for corresponding Mat. Effects ID. This goes for Scanline Rendering. But this would seem artificial. if you use mental ray renderer with mental ray shader's lume tools (Glow & Glare) it renders the glow or flare effect not only on the source object but also on the reflected surface which is a common phenomenon in real world. and to remind u, some of the shaders in mental ray are locked which you have to unlock by editing the \3dsmax7\mentalray\shaders_standard\include\lume.mi and removing the lines quoted as "hidden". but before in hand make a backup of the .mi files that u are going to edit. thanks shan Link to comment Share on other sites More sharing options...
kalatheart Posted July 14, 2005 Share Posted July 14, 2005 hi there, i agree with shan ... you can use the video post to give the glow... but that wont add to realism... well actually it depends what pupose exactly you need the glow for ... if it is for some interior scene .. i wd suggest you use mental ray lume tool shaders . they are an amazing way to acheive the desired g;ow effect ... if u can telll us in more detail about the scene that u r trying to set up .. i think we can help u better.. best luck kamal Link to comment Share on other sites More sharing options...
Brian Cassil Posted July 14, 2005 Share Posted July 14, 2005 Assuming this isn't for an animation, I always use PS to create glows. Just create a selection for the areas you want to glow, copy up a layer or two, and blur a little. Or you can even render a self-illumination pass and set it to screen blend mode in PS and blur that once or twice. True, the glows wont appear in reflections though. Link to comment Share on other sites More sharing options...
Munz Posted July 18, 2005 Author Share Posted July 18, 2005 Thanks everyone for the help, I ended up just doing the glow in photoshop this time, but will try other techniques in the future, here is the image I was working on. thanks munz Link to comment Share on other sites More sharing options...
