qwarto Posted July 14, 2005 Share Posted July 14, 2005 i'm lost doing mr rendering so i started with vray and here's my attemp. can anyone help me improve on my lighting and rendering it seems to me its a bit dark. i have 1 direct light and 1 vraylight just outside the window. i'm using 3dsmax 6 Link to comment Share on other sites More sharing options...
kaylmyers Posted July 14, 2005 Share Posted July 14, 2005 post your render settings... Link to comment Share on other sites More sharing options...
makemono Posted January 16, 2006 Share Posted January 16, 2006 I think that you should play a little (if everything else is ok) with the color mapping.Try exponential or gamma correction and play with the settings. Also you can play with the vray's frame buffer, which has a real time curve. And if you want change the color of the sky.It's a little strange and unusual that sky and that light.Try sth softer and whitish with a blue tint.When we see your setting we might help more:) Link to comment Share on other sites More sharing options...
kingkelly Posted January 18, 2006 Share Posted January 18, 2006 I would throw in another vray light pointing at that corner. And in vray under color mapping (or whatever the rollout is called), up the darkness value to 2. That will brighten up all the dark areas. Link to comment Share on other sites More sharing options...
arquiteck09 Posted January 18, 2006 Share Posted January 18, 2006 the "exponential" option under color mapping settings mey help as well. Link to comment Share on other sites More sharing options...
Tim Nelson Posted January 18, 2006 Share Posted January 18, 2006 It's all about gamma corrected rendering. It has been the topic of much discussion on the vray forums lately, and Chris Nichols covers it on his interiors dvd as well. Basically it explains why Vray renderings always seem to start out being too dark with too many hot spots when using linear color mapping. (hint: try using gamma correction color mapping and set the bright mult. to .4545) There's more to it than that, but that will set you in the right direction. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted January 18, 2006 Share Posted January 18, 2006 A quick look at Throb's page may get you started: http://throb.net/site_main/LinearWorkflow.html Link to comment Share on other sites More sharing options...
