Brian Cassil Posted July 15, 2005 Share Posted July 15, 2005 I need to find the best method for exporting models from Max to Lightwave. I could simply export my max model to .3ds and then import that, but I would really, really, REALLY, like to be able to have all the objects grouped by materials when I open it in lightwave. Is there anyway to do this? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 15, 2005 Share Posted July 15, 2005 Well, don't know much about LW, so this may sound silly... What formats does LW support? Is OBJ one of them? Link to comment Share on other sites More sharing options...
Brian Cassil Posted July 15, 2005 Author Share Posted July 15, 2005 What formats does LW support? Is OBJ one of them? I'm told that it supports .obj "natively". I've only exprorted to .obj once and I have no idea how it turned out on the other end. There are a lot of export options in max for .obj. I can see that one of them is "group by: material", so this sounds like a good route to me. However, I'm not sure what to do with some of the other options like, exporting a material library, rotate model?, faces as triangles, quads, or polygons?, etc. I've tried exporting and re-importing to max and all seems fine except for some really strange smoothing. It would sure be nice if there was some type of demo-version of LW I could use to import models I've exported from max with different settings. Link to comment Share on other sites More sharing options...
manta Posted July 15, 2005 Share Posted July 15, 2005 If you don't have lightwave, why do you want to exoprt them to it ??? Anyway try FBX... Link to comment Share on other sites More sharing options...
Brian Cassil Posted July 15, 2005 Author Share Posted July 15, 2005 For someone else to render my model with. FBX? Link to comment Share on other sites More sharing options...
Brian Cassil Posted July 15, 2005 Author Share Posted July 15, 2005 Ok, found wht FBX is. I'll give it a try. One question, it says that before exporting from max I should reset all transforms. How do I do that? Link to comment Share on other sites More sharing options...
ihabkal Posted July 15, 2005 Share Posted July 15, 2005 there's a reset transform utility in the utilities paner at the far right. Link to comment Share on other sites More sharing options...
