rendering size
long_cg
Hi,
Usually the render setting for print out varies depending on the Paper Size. For A1 size paper @ 150 dpi the render setting would be 4966 x 3507 pixels, which would be a better quality. But some times you could use 100 dpi since not always you would observe a A1 size print very close to it but at a decent distance which would not require greater than 100 dpi print resolution.
If you are using 3ds max, there's a handy useful option " Print Size Wizard" which gives the freedom to feed the paper size and optional dpi value to which the render size in pixels is automatically calculated.
shan
in theory, 4000x3000@72 dpi is a bit low, but in practice i think you'll find it more than acceptable ;) try it
depends what the finished output is intended for. we print out A1 colour prints rendered at 2000x1500@72 dpi, and size them up in photoshop. they're suprizingly crisp and nice.
