2 novice questions..
only3d
im not really a novice just a little lazy (or buisy 2 b more accurate)
so #1- how do i get the materials 2 show in working mode without rendering
and #2- how do i insert an image (like raster image in autocad)
tnx!
p.s.- can i do #1 in viz3 ?
#1 - in the material editor there is button, just below the material slots, that is a checkered box. toggling this on and off will show or not show your material in the viewport. - this is done on an individual material basis
#2 - views / viewport background or alt+b
cheers mate!
only 1 problem- after i insert the image it stays constant in viewport size
so is there a way to load it so it remains in its original size?
(its hard 2 model by it if it changes every zoom in or out)
tnx in advance
only 1 problem- after i insert the image it stays constant in viewport size so is there a way to load it so it remains in its original size?
hit alt+b and in the aspect ratio group select Match Bitmap
Olli
if i make an object (lets say a tube) using nurbs and then i want 2 add a curve with whom i can fiddle then how do i do that?
it sound basic but 4 some reason it doesnt work, so any ideas?
(also a pic 2 explain wat i mean)
