Extrude
stevefigueras
Hello everybody it's my first post on this forum an di hope you will able to help me ! :)
Here my problem : i have a plan of a city and all the street are representated in the same color , and all the building in another one !
This plan is well detailled and it is on background or an a bix box !
I know that it's possible but i don't know how to procede to manage it !
I want that 3DS MaX build automatically street and generical building on the emplacement of the color !
Can i extrude the box point per point in fonction of the different colors ?
Thank you for your help !
Steve
My plan is a bitmap or jpeg of 3000 * 3000 pixel in black and white , white for the street and black for the rest ! It's a city plan and i want that 3dSmax build automatically the street in 2D plane and i want thaht 3dsmax build automatically the buiding with the form they have on th emap !
Thank you sear for your attention and for your answer !
steve figueras
you could try using the jpg as a displacement map....make a plane the size of your picture (AxB) ...then put the jpg in the displacement map of a material add the material to the plane, then add a displ aprox modifier and adjust the gizmo....with a little tweaking you should get the buildings to be one height and the streets below them....convert the plane to a patch and them subdivide into smaller segments to get a more precise model
Thank you for your answer amarkovi but can you explain me with mor detail this?
" with a little tweaking you should get the buildings to be one height and the streets below them....convert the plane to a patch and them subdivide into smaller segments to get a more precise model "
1) you make a plane the size of your jpg
2) you open the material editor and assign your jpg to the displacement map slot
3) then you add a Disp Approx modifier to the plane
4) render and you should get the white areas of your jpg elevated and the black areas should stay at zero elevation
you will probably need to adjust the number/size of segments your plane is made of to get a more accurate model either by converting the plane into a patch (select plane, right click mouse, convert to patch) and then make the subdivision greater or by adjusting the number of segments of the plane when you create it......also when you add the Disp Approx modifier the rollout has three options for a small-medium-large mesh, but this will depend on the number of segments the plane is made of
I think it would be better, though, to create a real model by using the jpg as a plan and then making boxes the height you need....it will maybe take more time to create but you will have an actual model....using a displacement map is good for landscapes but I'm not sure it would work too well for your case.....actually it all depends on how you plan to use the model later...try it and see what works best for you
Here you can find an extract of my map . If you want to show me by an example i can follow your instruction !
On more i have en french version of 3dsMax and my english isn't perfect ! :D
Could you take this extract , make the modification an send me an archive ?
Thank you , you're helpful !
Steve :rolleyes:
stevefigueras@yahoo.fr
stevefigueras@hotmail.com
