jar73186 Posted July 20, 2005 Share Posted July 20, 2005 Does anybody know how to use a jpg or picture file that has an emblem in the middle with nothing on the sides to create a sign with just the emblem. I really would prefer not having to model a plane in the shape of the outside edge. I thought there was a way to take a tif and appy it so you can just have the area that is not transparent, but when I try this it shows the area that was formerly transparent as Black. If anybody has any idea it would be good Thanks Adam Link to comment Share on other sites More sharing options...
IC Posted July 20, 2005 Share Posted July 20, 2005 If the 'transparent' part is actually white or black, make a monochrome version with the emblem in contrast to the background and use this as an alpha map for your image. Link to comment Share on other sites More sharing options...
Msamir Posted July 20, 2005 Share Posted July 20, 2005 Thanks Adam Off topic but is your name John or Adam ?! Link to comment Share on other sites More sharing options...
jar73186 Posted July 21, 2005 Author Share Posted July 21, 2005 First name is John but I go by Adam Link to comment Share on other sites More sharing options...
IC Posted July 21, 2005 Share Posted July 21, 2005 That's great but how did you get on with your sign problem? Link to comment Share on other sites More sharing options...
jar73186 Posted July 21, 2005 Author Share Posted July 21, 2005 I went into Photoshop. Edited the original Jpg. saved it as a tif. originally when I edited I used the color selection tool and it had areas that it didn't remove when I made the edges transparent. Then I put it in viz and it worked. I have to get more used to using the path tool it works a lot better than any Lasso tool or the color selection tool. Give me some time and I will post the finished product for critiques. Adam Link to comment Share on other sites More sharing options...
