Hozz Posted July 21, 2005 Share Posted July 21, 2005 Hi guys .. its been long time since my last post here .. i was in vacation from work .. anyway .. am using max 7 now .. and am always use a skylight in my projects coz i like the soft shadows that it gives .. but this time when i rendered the scene i got a very bad thing its look like a spots of diffrent colors all over the place .. and it makes like this only when i use the skylight .. so anyone can help me with this ?? and i use the default render "scanline" thank u all Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 21, 2005 Share Posted July 21, 2005 are you using radiosity? if so, thise blotches usually can be fixed by adjusting any or all of the following settings; use regathering, increase your initial quality, increase refine iterations, or lower the size of the filter. these settings reduce the variance of shading. some adjustments work better with each lighting set up. adjust one at a time and test render. Link to comment Share on other sites More sharing options...
Tim Saunders Posted July 21, 2005 Share Posted July 21, 2005 ooh, p.s. i love the glass on your end table. would you mind posting your settings? Link to comment Share on other sites More sharing options...
