Michael Earley Posted July 21, 2005 Share Posted July 21, 2005 I have searched the web a bit and have not really found any answer. I need to render a wireframe of a model. I have tried to appy a material and a uvw map and still do not get anything that I can make an image of. thanks for your help michael Link to comment Share on other sites More sharing options...
ecastillor Posted July 21, 2005 Share Posted July 21, 2005 if its an standar material, there is an option in the material shader basic parameter called wire....check that. if its an imported wireframe imported from autocad made up of plines or lines, check renderable in the rendering tab of the objecys properties.... Link to comment Share on other sites More sharing options...
Michael Earley Posted July 22, 2005 Author Share Posted July 22, 2005 Thank you very much. I had found a tutorial that was very involved and thought there had to be an easier way... thanks again michael Link to comment Share on other sites More sharing options...
