nhj84 Posted July 23, 2005 Share Posted July 23, 2005 Hallo I'm having some problems with my renderings (again). I've included an example... As you can see there are "edges" from the "renderbox" (most clear in the top left section)... Does anyone know why? Also there is "boxes" i the top which have another teint than the others... This is only a problem when I use distributed rendering? Anyone know what is going on? Link to comment Share on other sites More sharing options...
nhj84 Posted July 23, 2005 Author Share Posted July 23, 2005 by the way I use Vray advanced.... Link to comment Share on other sites More sharing options...
JamesTaylor Posted July 23, 2005 Share Posted July 23, 2005 do you have different versions of vray installed on the different machines? i had this problem a while ago and that turned out to be the cause. Link to comment Share on other sites More sharing options...
nhj84 Posted July 23, 2005 Author Share Posted July 23, 2005 No I'm certain it's the same version... Link to comment Share on other sites More sharing options...
nhj84 Posted July 24, 2005 Author Share Posted July 24, 2005 Oki doki... Found the problem... For some reason the render server couldn't find the floor texture... Link to comment Share on other sites More sharing options...
