vray problem
carlangas
hello all,
I have this problem with shadows. as you can see in the pic, Im getting these blackened areas where shadows are cast. It wasnt doing it before, i dont know what I did that makes it look like that. little help??? anybody please.
im using max6 vray 1.47.03
thanks
It doesn't seem to like applying shadows to that sand material.
Is the sand material a Standard or Vray Material?
I've had similar problems using Standard materials whilst rendering with Vray
If it is a Vray Material then have you accidentally applied some type of troublesome bump map?
hi,coplanar faces are where the object has no thinkness,like a plane.
looking at the white canopy beyond the problem area,this has coplanar faces on it, the bark squares that are all over it.
try to give the objects some thinkness by extruding...
cheers.
