oferv750 Posted July 24, 2005 Share Posted July 24, 2005 i have a new comp pentium 4 3.0 with 1gb of memory iam tring to render afram in 3dsviz4 & its taking to long (4 min) iam having problems with my comp & idont know whot to do i have rendered the same fram on a difrent comp (pentium 4 2.8 with 512 mb of memory) & it was done in 10 sec please tell me whot to do or whot to chec i am desperet thanks ofer v Link to comment Share on other sites More sharing options...
Jennifer Posted July 24, 2005 Share Posted July 24, 2005 A lot of things go into the rendering speed of a computer. If your old computer has a faster hard drive and dual-channel memory, it may well outperform your new computer if it doesn't have that advantage. But, that is quite a difference in speed! Usually when the program takes a long time for me, it is spending too much time searching for bitmaps for the materials, especially if it is trying to search to network drives that may not be on-line. Ensure that all your maps are local to that machine, and not on a network drive, or at least move all used maps to the local machine. In the Tools tab, use the Resource Collector to copy the maps used in the scene to a local location; it can also update the materials to look there first. I also create a "\maps\NetMaps" folder as a 'catch all' for quick access to maps in a project. I add that to the Configure > Configure Paths and the 'External Paths' tab, at the top of the list, and use the Resource Collector to put the maps there. When the project is done it is fairly safe to delete the contents of that folder since they are copies. Good luck! Link to comment Share on other sites More sharing options...
oferv750 Posted July 24, 2005 Author Share Posted July 24, 2005 A lot of things go into the rendering speed of a computer. If your old computer has a faster hard drive and dual-channel memory, it may well outperform your new computer if it doesn't have that advantage. But, that is quite a difference in speed! Usually when the program takes a long time for me, it is spending too much time searching for bitmaps for the materials, especially if it is trying to search to network drives that may not be on-line. Ensure that all your maps are local to that machine, and not on a network drive, or at least move all used maps to the local machine. In the Tools tab, use the Resource Collector to copy the maps used in the scene to a local location; it can also update the materials to look there first. I also create a "\maps\NetMaps" folder as a 'catch all' for quick access to maps in a project. I add that to the Configure > Configure Paths and the 'External Paths' tab, at the top of the list, and use the Resource Collector to put the maps there. When the project is done it is fairly safe to delete the contents of that folder since they are copies. Good luck! thank you jenifer itried whot yuo sajested & it dosnt work iam convinced thet it is a hardware problem ¬ a software problem thanks ofer v Link to comment Share on other sites More sharing options...
